주요 콘텐츠로 건너뛰기
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
496 질문 전체 보기
only sensing light comes on.
i have a kenmore series 500 washer. model number-110.25102310 the washer stopped in the drain cycle with lid locked light on. i canceled the cycle and tryed to restart on the drain/spin cycle. only the sensing light came on with a faint click but lid lock will not engage. i unplugged for awhile and plugged back in. tried entering diagnostic mode and will not go int it. the sensing light keeps coming on and nothing else. even after unplugging for awhile and plugging back in it will come on after about 10 seconds.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi @tman3225
Did you try the auto test mode diagnostics or the manual test mode diagnostics?
If auto try the manual (see p.4 & p.9) of the tech sheet to see if you can isolate the problem by testing the individual functions of the machine.
If no good try checking the main control board voltages as per Test #1 main Control on p.12
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
When trying to enter into diagnostic mode per the tech sheet. I could not get it to. I’ve done it before when it would continuously run cycles a few years ago. I will check control board now.
Definitely the control board. Getting a new washer. Thanks
댓글 달기
귀하의 답변을 추가하세요
tyler phillips 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 18
전체 시간: 246
