주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2019년 11월에 출시된 MacBook Pro 16''의 수리 안내서 및 분해 정보입니다. 모델 A2141, EMC 3347.
USB-C Board Replacement?
Hello, has anybody replaced the USB-C Board on either of these MacBook Pros?
MacBook Pro, 15" Touch Bar, 4-port
(2019, Model A1990, EMC 3359, 15,3)
MacBook Pro, 16" Touch Bar, 4-port
(2019, Model A2141, EMC 3347, 16,1)
There isn't a repair guide available for either model that covers a USB-C Board replacement.
Thank you...
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hi
If you follow this video here it will show you how to remove the logicboard
Here’s one for the 15" MacBook Pro A1990 2019 Logicboard Removal
Here’s one for the 16" Inch MacBook Pro A2141 Logicboard Removal - Liquid Damage
If you want to replace your USB-C ports you just need to remove the screws ether side of the port then they should just slide out
Hopefully this helps
Any questions please ask
이 답변이 도움이 되었나요?
점수 3
댓글 달기
가장 유용한 답변
All USB C boards on these Pro models, from 2016 on, regardless of size, are similar in process.
Follow the 16" Guide for Battery Replacement, up to step 66. This gets the logic board out. Disregard anything after. Unless you also want to replace the battery while you've got it gutted.
After that, use T5 drivers to remove the screws holding in the USB C boards. Two screws per board.
After the screws are removed, you just have to pull them out of the top case. Et voila. Reverse process with new ones. Or clean the existing ones and reinstall.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
답변을 추가하세요
bobjohnston 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 58
전체 시간: 1,664
