주요 콘텐츠로 건너뛰기
Apple은 MacBook Air 13"를 2017년 6월에 새로운 Broadwell Intel Core i5 프로세서로 업데이트하여 성능과 배터리 수명을 약간 향상시켰습니다.
423 질문 전체 보기
Macboook wont turn on, charger changes color when pressing power
So my macbook just stopped working. When I try to turn it on, it just won't. When I unplug the charger and battery and plug it back, it works, but after shutting it down from OS, the problem is back. Also when I put it back to charger, the light is orange and when i press the powerbutton, it changes color to green for 3 seconds and than changes back. I tried SMC and PRAM reset and still nothing. Any help please?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
What you are encountering is SMC going into a locked state so it won't let you startup the next time as it has a serious failure condition. So now we need to discovery what SMC sees but fails to report to you.
You'll need to reset SMC a few times here. This time just disconnect the battery, then with nothing plugged in, press and hold the power button fo a good 15 secs to fully discharge the logic board. Now do the following:
So lets startup with checking the battery and the charging logic. Install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 기존 질문에 이미지 추가하기
Next let's run the onboard diagnostics press the D key after clearing SMC, did you get any errors?
References:
해당 답변은 도움이 되었습니까?
점수 1
댓글 15개:
I have done what you said. The diagnostics reports some issue with camera, but nothing with SMC or power issues. Also, after running the diagnostics, the it works again, I can shutdown and turn of the computer again, but when I leave it for like 30 minutes and more, the problem is back and the computer won't turn on again. Is there any way how to reset SMC from OS? Like using some software or utility? Thanks for help!
@Vlastimil Hrabovský - The camera is the issue then which will also tell SMC to go into a locked state. SMC is a Systems Management Computer (SMC) it deals with all of the house keeping of the systems health. And depending on which sensor has encountered an issue it will do different things.
So now we need to locate what is the problem with the camera. Do you have any visible damage to the display? Did you get the system wet or have a spill? Did you open the system to clean things or something?
I had to clean logic board because of mass of corrosion on whole board. I will check the camera connection. Thanks a lot!
So I've even tried different camera, but the error occurs again. However, both of the cameras are working in operaing system. What should I do next? I'm going to inpect the board again. Could reflowing the SMC chip help? Thanks
@Vlastimil Hrabovský - I doubt reflowing the SMC chip will help here, Liquid damage tends to cause corrosion damage some have be hidden! Tracing out the circuit is what I would do to discover if the logic board connector or which SMD device is bad due to shorting out underneath.
댓글 10개 더보기
댓글 달기
귀하의 답변을 추가하세요
Vlastimil Hrabovský 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 119
