How to fix Touchpad, Replace or clean it?
I need help on how to fix my laptop touchpad
좋은 질문입니까?
좋은 질문입니까?
Hi @onionshake
What is the status of the touch pad in Device Manager?
Go to Device Manager > Mice and other pointing devices > right click on the touch pad entry > Properties > General tab. In the Device Status box, does it show "This device is working properly"? If so then there's a hardware problem with the touchpad, e.g. faulty touchpad, loose cable etc.
Here's the maintenace and service guide for the laptop. On p.79 is shows that you have to completely dis-assemble the laptop to get to the top cover/keyboard assembly so that you can access the touchpad.
If it is determined that it is faulty, I'm not sure if you can get a separate touchpad or if you have to get a complete top cover/keyboard assembly which includes the touchpad. The country specific part numbers for the top cover assembly are also found on p.79. Search online using the part number only appropriate to your model to find suppliers. Usually the part number can also be found somewhere on the underside of the assembly if you wish to verify the number.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 3
지난 30일: 21
전체 시간: 540
댓글 2개
Hi Gilbert,
What kind of problems are you having with the touchpad? Knowing that will help the rest of us try and figure out the best way to help you.
Jerry Wheeler 의
@dadibrokeit my laptop is HP 250 G6 and the touchpad is not working I already tried downloading the latest drivers but its still not working
Gilbert Busilig 의
