주요 콘텐츠로 건너뛰기
The Fitbit Versa 3 is a smartwatch released on September 25th, 2020. It features a larger display and built-in GPS.
What glue should be used to adhere the watch screen?
My Fitbit Versa 3's screen is starting to lift up and fall off. There's no damage to the bezel, and no issues with the battery or display so far. I'm not worried about how waterproof it is, I rarely if ever even splash it when washing my hands. I'm mostly concerned about solidly adhering the display down so that no damage can occur to the electronics or wires. I had tried taking it in to a local repair place, and they said they glued it down, but the adhesive they used failed within two months. If I gently lift the screen, I can only get about a 1-2mm gap to place any adhesives, so liquids would probably be the best option. Which would be the best option? Some sort of silicone glue or superglue? Something like B-7000?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi @kurin ,
Instead of a glue maybe try some Tesa 61395 Tape.
This is a double sided adhesive tape which is only 0.5mm thick and you can get it in various widths to suit. You can also get the pre-cut adhesive card which has various sizes in case you don't won't to get a whole roll of tape. (click on the box with 1mm size listed and scroll down and click on pre-cut adhesive card to see what it looks like)
It is used to seal/secure screens to the case in mobile phones so I think it should be suitable for what you want.
Custom cut rolls of Tesa 61395 double-sided tape for repair. 이미지
제품
Tesa 61395 Tape
$5.99
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Kurin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 55
전체 시간: 5,014
