주요 콘텐츠로 건너뛰기
모든 Apple 휴대용 태블릿 컴퓨터의 포괄적인 수리 설명서. 많은 경우 수리는 열처리와 조심스럽게 비집어 열기가 필요합니다.
5763 질문 전체 보기
Why is my keyboard divided into two parts?
Recently my keyboard became divided into two parts with a space between the parts.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 12
댓글 4개
This worked perfectly. Thanks.
I thank you, too. I was baffled by this sudden weirdness until I had an epiphany and googled the question.
my keyboard showing merge letter how to split it
I have an amazon tablet and it doesnt work..
댓글 달기
답변 4개
선택된 답변
Just use your thumb and forefinger to pinch the two pieces together again. The split keyboard is a feature of the iPad to make it easier to type while holding it.
해당 답변은 도움이 되었습니까?
점수 8
댓글 4개:
Thank you crazy things happen,thanks for quick help.
Fantastic thank you x
been trying the whole night to figure it out
thanks!
Such a simple fix but I would not have guessed it on my own! Thanks for the solution!
댓글 달기
there should also be a toggle in settings>general>keyboard :)
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Thanks ! Too hard using two sides of my brain at once .
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The toggle version couldn't work cause my settings, general, does not the third option keyyboard.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Carole Feingold 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 23
전체 시간: 23,580
