주요 콘텐츠로 건너뛰기
10월 13일에 발표된 iPhone 12 mini는 Apple iPhone 12의 소형 버전입니다. iPhone 12 mini 특징은 5.4인치 OLED 디스플레이, A14 Bionic 프로세서, 그리고 듀얼 후면 카메라 입니다.
73 질문 전체 보기
What adhesives need replaced when replacing the Rear Camera?
I'm researching how to replace the rear camera on my 12 mini. What adhesives do I need and are they necessary?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi Jeremiah,
I haven't opened up a 12 mini myself, but I've done enough other models that I can speak with some experience.
After reviewing the rear camera guide, it looks pretty sure that the only adhesive you need is the iPhone 12 mini Display Assembly Adhesive. It looks like iFixit is out of stock at the moment, but it's readily available on eBay and Amazon.
From personal experience, I'd suggest getting a couple; it's all too easy to get them stuck in the wrong place and end up with an unusable tangle of sticky, then you end up having to wait while you reorder to finish the job. They're cheap; you can get two of them on eBay with four day deliver for about $4 USD.
As to your question of are they necessary, my answer would be, absolutely.
  1. If you end up tearing or tangling the adhesive while you're opening the screen, it won't be nearly as secure when you seal it back up, if it's usable at all.
  2. While you may not get back the original quality of the waterproofing that the phone came with, using new adhesive will get you as close as is possible with regard to keeping water out of your phone.
iPhone 12 mini Display Assembly Adhesive 이미지
상품
$6.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Apple already provided everything you need to know.
https://manuals.info.apple.com/MANUALS/2...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Jeremiah Ondrasik 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 76
