주요 콘텐츠로 건너뛰기
Dell Latitude E7270 12.5 inch laptop
Ethernet jack replacement, has more than 8 pins?
Hi,
My ethernet jack on my laptop is not working properly and only works when I push at a certain angle, I opened it up to see what the port looks like and see if I can find a replacement that will fit.
Here is the photo of the jacky as you can see it has extra pins apart from the 8 standard rj45 connector pins.
Does anyone know what these are for or are they just for support? Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
I saw that listing on aliexpress too, from the photos the closest one that match is 32 or 35.
댓글 달기
답변 1개
가장 유용한 답변
Hi,
The extra connections may be for the LED lights next to the RJ45 jack if it has any.
Here's a schematic of the RJ45 setup from a Dell 7470 ( LA-461P motherboard - I couldn't find a free schematic for a 7270 LA-451P motherboard ) which shows the connections. Hopefully they are similar.
The part number is 130456-511 but I had no joy when searching for it either.
(click on image to enlarge)
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks that makes sense, how can i forget the LEDs would need connections too! I found some that might fit but without the LED legs, mentioned in the comments of the original post. If it doesn’t i might just have to deal with using a usb ethernet dongle
댓글 달기
답변을 추가하세요
Eddy M 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 256
