주요 콘텐츠로 건너뛰기
Repair documentation for the Sony PlayStation 5 DualSense controller. Model number: CFI-ZCT1W FCC ID: AK8CFIZCT1
81 질문 전체 보기
L2 Button constant on even if not pushed
Hello,
i changed the two rings around the L3 button which caused stick drift , after getting all stuff together my L2 Button is like always enabled even if im not pushing it at all. How can i fix this ? Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Try taking the controller apart again and then push the L2 button then release. If that doesn't work ,try replacing the trigger button. Hope this helps!
Diode
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
tested some stuff and the L2 is even activated after i removed the left L1 and L2 unit from motherboard. So its something with the board i assume.
@Toni Montana Seems that way. All right. I don't know if I can help you in any other way. Sorry.
its a problem with the blue flat cable that connects the unit to the main board… try straightening the metals at the tip… worked for me
댓글 달기
귀하의 답변을 추가하세요
Toni Montana 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 12
7일 전: 131
30일 전: 699
전체 시간: 9,914
