주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1286. 2011년 2월 출시 / 2.0, 2.2, 또는 2.3 GHz 쿼드-코어 Intel Core i7 프로세서
Logicboard from later year?
Hello. I have a macbook pro that died a while back and I want to see if swapping out the logic board will fix it. No real experience besides piecing together desktop PCs.
My macbook pro has 820-2565-A.
Could the 2012 version of A1286 be inserted? Replace it with 820-3330-b
I bought in 2011 before thunderbolt was released. Wondering if I can put in a newer version to give it thunderbolt access. Not too important since it is a decade old. But figured if I go through with the effort...
Is this possible? Thanks ahead of time.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
While it doesn't matter your 2011 system mDP is in fact a Thunderbolt port. If you bought in the first weeks of its release there was a firmware upgrade that was required to enable it. Depending on the OS-X/MacOS release you've upgraded to over the years you likely had it upgraded a few times (I think its about 6 or 8 releases to the last one)
댓글 달기
답변 1개
선택된 해법
OK so lets get down and dirty! The system I'm banging on right now was a early 2011 15" which I upgraded the logic board to a 2012 board. So clearly it can be done!
Here's the needed part:
Presently iFixit only has the 2.3GHz board in stock and here's the guide to take yours out and put the new one MacBook Pro 15" Unibody Mid 2012 Logic Board Replacement You might find the board you want on another part site.
The only proviso is you need to make a slight modification of the LVDS cable. Nothing hard! Just use a nail file to file down the fiberglass tang. Here's the needed info:
You likely need a new battery as well! MacBook Pro 15" Unibody (Early 2011-Mid 2012) Battery
Replace a 2.3 GHz Core i7 logic board (motherboard) compatible with the Mid 2012 MacBook Pro 15" Unibody laptop. Included Ports: Thunderbolt (Mini DisplayPort), 1000BaseT Ethernet, Firewire 800, 2 USB 2.0, SD card slot, Audio In, Audio Out. Fix processing issues like unexpected shutdowns, reboots, or water damage. 이미지
제품
MacBook Pro 15" Unibody (Mid 2012) 2.3 GHz Logic Board
$149.99
Replace a 2.7 GHz Core i7 logic board (motherboard) compatible with the Mid 2012 MacBook Pro 15" Unibody laptop. Included Ports: Thunderbolt (Mini DisplayPort), 1000BaseT Ethernet, Firewire 800, 2 USB 2.0, SD card slot, Audio In, Audio Out. Fix processing issues like unexpected shutdowns, reboots, or water damage. 이미지
제품
MacBook Pro 15" Unibody (Mid 2012) 2.7 GHz Logic Board
$179.99
Replace a 6730 mAh battery compatible with MacBook Pro 15" Unibody Early 2011 to Mid 2012 A1286 model laptops. 77.5 Watt Hours (Wh). 10.95 Volts (V). Part #661-5844. Battery model #A1382. 이미지
제품
$69.99
Replace a 2.6 GHz Core i7 logic board (motherboard) compatible with the Mid 2012 MacBook Pro 15" Unibody laptop. Included Ports: Thunderbolt (Mini DisplayPort), 1000BaseT Ethernet, Firewire 800, 2 USB 2.0, SD card slot, Audio In, Audio Out. Fix processing issues like unexpected shutdowns, reboots, or water damage. 이미지
제품
MacBook Pro 15" Unibody (Mid 2012) 2.6 GHz Logic Board
$194.99
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Thanks it just came in the mail! Hopefully all goes smoothly...
Success! Wish I knew about this 3 years ago when it failed... I will look into a new battery. Thank you!
댓글 달기
답변을 추가하세요
Matt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 13
전체 시간: 251
