Bmw 530i 2006 no injector pulse
2006 bmw 530i no injector pulse crank but no start. Starts with starter fluid but shuts right off after starter fluid runs out. Has spark has compression and timing is good what could be the problem?
좋은 질문 입니까?
좋은 질문 입니까?
Hi,
Can you hear if the fuel pump is operating?
There is a fuel pump relay (K96 - relay panel behind glove compartment) that is operated by the ECM and the pump should operate as long as the ignition key is in the start position and then the pump will continue to run once the engine starts.
Also check if the fuel pump fuse (N52 engine - rear fuse holder fuse F50) is OK or not.
Hi,
Here's the BMW E60/E61 2004-10 – Fuel Injection MSV70, MSV80 (N52 Engine) section from the service manual that may help to find out what's happening
해당 답변은 도움이 되었습니까?
Yes fuel pump is active and has great pressure in the fuel line. Definitely enough, I tested it through the fuel rail test valve and it shoots with pressure
24 시간 전: 0
7일 전: 2
30일 전: 23
전체 시간: 1,032
