What is broken? No display and Power / Fn buttons flickering
I'm asking because I've never encountered these symptoms with any computer ever before.
Symptoms:
- flickering power and Fn buttons
- laptop screen blank
I replaced the mainboard of my X270 with one bought from a Chinese store. I've done that before on other laptops of the same model and with different models. although no professional hardware technician, I'm familiar with that kind of work.
I installed the replacement and booted up. The symptoms are as described above; the laptop screen is staying blank and the power and Fn buttons are flickering. Not blinking, flickering. This does not at all look like a post error blinking, it's way too fast.
The flickering might have a pattern that repeats after a pause, but that's just a feeling and I first need to actually record the timings.
With an external screen attached, the system can be used fine, but the flickering of the power button persists.
It's a very weird error. Do you have any clue about what could be broken and how does it cause the symptoms. Or are they unrelated?
I'm baffled.
p.s.
I rechecked the flickering of the Power and Fn buttons; there is a pattern and it's five flashes in about 0.5s, every 1s.
좋은 질문 입니까?
댓글 3개
Sounds like a loose connection somewhere. Recheck all especially for screen.
mike 의
Did that, will do again.
esarbe 의
I checked all connections, they seem fine. I also checked with another panel and got a similar issue (flickering picture instead of no picture, but still no working picture). I checked the panel on another laptop and the panel seems fine.
To me it currently looks like there's something wrong with the motherboard itself.
Thanks for your help, much appreciated!
esarbe 의
