주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/32/64/128 GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
Boot Loop On Plug-in, Button Fixes Do Not Work
My phone will instantly boot-loop on connection to power, white apple logo.
Will restart every 10 seconds.
Power + Home button holds do not work
Volume Up/Down buttons do not work.
Tried all buttons, the 'pressing onscreen trick' etc.
Nothing seems to work.
Of course, there is no connection visible on computer.
There is no response to any button holds whatsoever, the apple logo still loops every ten seconds.
Any body got a fix?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi
When its not turning on and it’s boot looping that usually means time for a new battery
Here’s a guide for replacing it!
iPhone SE 배터리 교체
Here’s a USA link for a Battery
iPhone SE (1st Gen) Battery
Here’s a EU link for a battery
https://eustore.ifixit.com/products/ipho...
Here’s a UK link for a battery
https://store.ifixit.co.uk/products/ipho...
If you are outside the stores I have listed please let me know and I can get you the correct link
Hopefully this helps
Any questions please ask
Replace a 1624 mAh battery compatible with a 1st generation iPhone SE. 3.82 Volts (V), 6.21 Watt Hours (Wh). This replacement does not require soldering. 이미지
제품
$29.99
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
It could be from water damage too, but most likely a battery issue for sure.
@cooltool
You are correct about the water damage,if they find any they can remove it while they are replacing it:-)
댓글 달기
답변을 추가하세요
Royal Toad Club 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 20
전체 시간: 94
