주요 콘텐츠로 건너뛰기
Xbox Series X는 마이크로소프트의 차세대 4K 콘솔 게임기 입니다. Xbox Series X는 2020년 11월 10일에 Xbox Series S와 함께 출시하였습니다.
67 질문 전체 보기
Why do I have an extra screw?
I followed the guide from How Fixit and even checked the guide here. I did the guide twice and for some reason, I have one 8.8mm screw and I can’t seem to figure out where it’s from. All the screws are in place according to the guides. Even when disassembling from start to finish and reassembling it back, I still can’t figure out where this one extra screw came from. Anyone have any idea where I should look?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi @kain05
Looking at the ifixit Xbox Series X Motherboard and Heatsink Assembly Replacement guide, there are 15 x 8.8mm screws.
If you open the guide and then do a search function (in Windows - Control key + f key then type 8.8 in the search box) it gives the location of the screws in the guide.
Hopefully you may find where the extra one goes.
해당 답변은 도움이 되었습니까?
점수 2
댓글 8개:
Thanks for the fast reply. But all the 8.8 screws that show up during the search on that page, have already been put in the same places. Is there other 8.8 mm screws on the Series X? Maybe one came loose somewhere else and I didn’t notice.
@kain05 there are 22 x 8.8mm screws shown in the Southbridge shield guide for the console.
Obviously some are the same but that means 7 more screws to check
Is that the only other guide with 8.8mm screws? If there is another guide with 8.8mm screws, post it. I don’t mind checking to make sure. I mean the console is working as it did before I disassembled it so. Plus, the more I do it, eventually I won’t even need the guide anymore. Also, thanks for the help.
@kain05
If you click on the device icon to the right of your question at the top of this page it will open the page with all the guides for the device.
Alternatively, here it is
I went for the ones which I thought would require the most dis-assembly to get at but I didn't look at all of them
Cheers
Thanks @jayeff
I appreciate the help. I’ll search within the pages for 8.8mm screws. Hopefully I’ll find out where this mystery screw came from lol. When I do, I’ll post it. Thanks again, I appreciate it.
댓글 3개 더보기
댓글 달기
귀하의 답변을 추가하세요
Kane 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 196
