주요 콘텐츠로 건너뛰기
Fitbit의 피트니스 모니터링 클립 기기.
2 질문 전체 보기
Battery door will not open with tool
I've used the tool that came with the fitbit zip but I'm wondering if i can pry it open without ruining it. It just won't turn to the unlock position so I can replace the battery
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
@dacqua prying it apart is not going to work. You will only break the mechanism of the cover or the cover itself. If the tool does not work, try a coin or a small washer and a pair of pliers to try and open the cover. You may not get enough torque with the tool.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had the same problem. After months of letting it sit, and replacing with a fitbit inspire, I tried a more extreme solution. I jb-welded the removal tool to the back of the fitbit, let it set for almost a day, and then was able to twist the back off normally. I used a razor blade to gently pry under the jb-weld until I could pry it up with my thumb and break it off. Then used the razor blade to further disconnect the jb-weld from the lid until it came loose. Now the tool fits better into the worn out back cover, and I'm back in business.
To more directly answer your question: yes, you would break it by forcing it out without twisting. Then you'd have to come up with another way to hold the battery in place tightly so it would make a reliable connection.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jean Lauri 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 19
전체 시간: 262
