주요 콘텐츠로 건너뛰기
The HP Pavilion A600 is a discontinued desktop computer tower produced by HP Inc., recommended for home use. Originally introduced in 1995.
1 질문 전체 보기
My hp pavilion elite m9500y has no video
My hp pavilion elite m9500y has no video I tried to boot it up you can hear the fans and everything but there is no video. I think it is the cpu or the gpu
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개
Hi @superfixer334,
Have you tried another monitor, video cable etc?
Is the HDD activity light working?
Most likely it is the GPU card although if it failed they may have been a beep error code on POST.
I have tried a different monitor and cable and the hdd light is solid green and there is no beep on boot up
@superfixer334
Can't find the manual so I don't know if there's supposed to be a single beep for a successful POST or not.
If not and there's no HP logo on startup it may not even be starting -motherboard?
If the HDD light flashes indicating it is booting into Windows then it's the GPU card. You could try starting in "safe mode" to check if it s a driver problem
The hdd light flashes one time I hold the power button down and my monitor does not get a Signal
Wait sorry I got the power supply light mixed with hdd light I can’t find a hdd light
댓글 달기
답변 1개
가장 유용한 답변
Hi @superfixer334
Disconnect power from the PC and hold the PC power button operated for a full 30 seconds then release .
reconnect power and try starting
If OK check the coin cell battery on the motherboard is OK i.e. >2.5V
if not replace it
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Evan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 175
