주요 콘텐츠로 건너뛰기
batterie fully charged Roomba instructs me to cha
Hi
I charge my Roomba fully, charge light is on green turn the Roomba on it runs fir 10 seconds and instructs me to charge again, I check the batterie and its fully charged, I have cleaned all contact point
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@ymaes2020 sounds like a battery issue. Fully charged means that you can see it has the required voltage but you do not know how the battery does under a load. The only way to be sure that your battery is working to specs is by doing a load tech which means you will need special tools and software etc. I suggest you start off with a new battery. If nothing else you can use that as a known-well starting point should any further troubleshooting be needed.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gary 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 83
