주요 콘텐츠로 건너뛰기
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
213 질문 전체 보기
No cold water cycle
Hi Everyone! Newbie here...
I am having a issue with my Maytag Bravos Model # MVWX655DW1. Works fine on hot cycle but will not run on anything else, warm or cold. The weird thing is the rinse cycle works with cold water on the hot wash cycle. A repairman came out and quickly told me it was control board. Bought a new one and installed but the issue is still occurring. I am getting error code F8 E1. There is SOOOOO much on youtube I am overwhelmed. Replace water inlet valve? Pressure Switch? I am lost and don't want to pay for someone to come out again, if possible. Money is tight at the moment and I'm already in the hole for a control board and a service call fee. Ugh...
Thank you for your help! Greatly appreciated.
Alan
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Did you ever find a solution? Im having exactly the same problem
댓글 달기
답변 1개
가장 유용한 답변
Hi @aedwards1982
Here's the tech sheet for the washer that will help.
On p.7 it gives the possible causes for a F8 E1 error code.
It details how to test the water inlet valves on p.13 Test #2: valves
If it is determined that the cold water inlet valve is faulty the part number is W11168740. Search online using the part number only, to find suppliers that suit you best.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Alan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 353
