주요 콘텐츠로 건너뛰기
Released August 2012, it is identified by its model number M4700.
3 질문 전체 보기
Need a specific spot picture to see what's missing
I got a dell m4700 from a friend but it doesn't work. He told me "I upgrade the ram and tried to change the thermal paste but I didn't know how to do it so I didn't and now it freezes on the dell logo" I replace the thermal paste and it still doesn't work but I found board damage so I would like to see someone's laptop to compare.
Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Roberto4273 it will work a lot better if you post images of your board with your QUESTION. Let us see what is missing/damaged etc. Edit your QUESTION and use this guide to add images 기존 질문에 이미지 추가하기 You also want to make sure that you give us any identification about your motherboard (not just the Make and model of your laptop but the actual board) just in case there are schematics for it etc. and from what I see it should be a Compal LA-7931P board Dell Precision M4700 LA 7931P Schematics
Dell Precision M4700 Motherboard Replacement
Update (09/18/2022)
Looks like you lost at least PQ503 which is a SSM3K7002FU_SC70-3D Mosfet. I suggest remove the board check for further damage and replace the transistor. It looks ( a bit hard to see) like all the solder pads are still there.
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
매우 쉬움
2 - 5 minutes
Dell Precision M4700 Motherboard 이미지
안내서
난이도:
조정
30 - 45 minutes
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I added a better picture
댓글 달기
답변을 추가하세요
Roberto4273 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 128
