주요 콘텐츠로 건너뛰기
Dell Precision M4700 Motherboard Replacement
필요한 것
  1. Dell Precision M4700 Motherboard Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Slide the release latch to unlock the battery.
    • Flip and remove the battery from the computer.
  2. Dell Precision M4700 Motherboard Replacement: 2 단계, 이미지 1/2 Dell Precision M4700 Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the two 3mm screws that secure the base cover to the computer with a Phillips #00 screwdriver.
    • Press the rubber tabs towards the rear of the computer to disengage the base cover.
    • Flip and remove the base cover from the computer.
  3. Dell Precision M4700 Motherboard Replacement: 3 단계, 이미지 1/2 Dell Precision M4700 Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the 3mm screw that secures the optical drive to the computer with a Phillips #00 screwdriver.
    • Slide the optical drive out.
  4. Dell Precision M4700 Motherboard Replacement, CPU: 4 단계, 이미지 1/2 Dell Precision M4700 Motherboard Replacement, CPU: 4 단계, 이미지 2/2
    • Pry up the keyboard trim starting from the top-inner edge with a plastic opening tool or spudger.
    • Pry up the bottom edge of the keyboard trim from the top-inner edge with a plastic opening tool or spudger.
  5. Dell Precision M4700 Motherboard Replacement: 5 단계, 이미지 1/3 Dell Precision M4700 Motherboard Replacement: 5 단계, 이미지 2/3 Dell Precision M4700 Motherboard Replacement: 5 단계, 이미지 3/3
    • Remove the four 3mm screws that secure the keyboard to the computer with a Phillips #00 screwdriver.
    • Starting from the bottom of the keyboard, separate the keyboard from the computer and flip the keyboard over.
    • Disconnect the keyboard-data cable from the system board by flipping up the locking tab of the ZIF connector and gently pulling out the cable.
    • Remove the keyboard.
  6. Dell Precision M4700 Motherboard Replacement: 6 단계, 이미지 1/2 Dell Precision M4700 Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove four 5mm screws that secure the hard drive to the computer with a Phillips #00 screwdriver.
    • Unscrew the 3mm Phillips #00 locking screw. Slide the release latch to unlock the hard drive.
    • Slide the hard drive out from the computer.
  7. Dell Precision M4700 Motherboard Replacement: 7 단계, 이미지 1/3 Dell Precision M4700 Motherboard Replacement: 7 단계, 이미지 2/3 Dell Precision M4700 Motherboard Replacement: 7 단계, 이미지 3/3
    • Remove the five 3mm Phillips #00 screws that secure the lower palm rest to the bottom of the laptop.
    • Remove the twelve 5mm Phillips #00 screws that secure the upper palm rest to the keyboard side of the laptop.
  8. Dell Precision M4700 Motherboard Replacement: 8 단계, 이미지 1/3 Dell Precision M4700 Motherboard Replacement: 8 단계, 이미지 2/3 Dell Precision M4700 Motherboard Replacement: 8 단계, 이미지 3/3
    • Disconnect the ribbon cables that connect the palmrest to the bottom of the device.
    • Pull on the tabs to disconnect the two wider connections.
  9. Dell Precision M4700 Motherboard Replacement: 9 단계, 이미지 1/2 Dell Precision M4700 Motherboard Replacement: 9 단계, 이미지 2/2
    • Pry up between the palmrest and case with a plastic opening tool, starting on the left side.
    • Work around the side farthest from the screen prying the palmrest up.
  10. Dell Precision M4700 Motherboard Replacement: 10 단계, 이미지 1/2 Dell Precision M4700 Motherboard Replacement: 10 단계, 이미지 2/2
    • Remove the two 5mm screws connecting the fan to the device with a Phillips #00 screwdriver.
    • Disconnect the wires connecting the fan to the motherboard.
  11. Dell Precision M4700 Motherboard Replacement: 11 단계, 이미지 1/2 Dell Precision M4700 Motherboard Replacement: 11 단계, 이미지 2/2
    • Unscrew the four captive screws with a Phillips #00 screwdriver.
    • Pull the CPU heatsink out. To remove it, grab the heatsink and pull it out and upward.
    • Captive screws should not be able to be removed. They only screw, they do not come out.
    • Be sure to clean both contact points on the CPU and heatsink with isopropyl alcohol and reapply fresh thermal paste before reinstalling the heatsink.
  12. Dell Precision M4700 Motherboard Replacement: 12 단계, 이미지 1/2 Dell Precision M4700 Motherboard Replacement: 12 단계, 이미지 2/2
    • Unlock the CPU by using flathead screwdriver on the circular lock and turning.
    • Using two fingers, grab the CPU and lift it directly upwards from the motherboard gently.
    • Once it is unlocked, it will come out very easily so do not use excessive force and be sure to avoid bending any of the pins located on the underside.
  13. Dell Precision M4700 Motherboard Replacement, Motherboard: 13 단계, 이미지 1/2 Dell Precision M4700 Motherboard Replacement, Motherboard: 13 단계, 이미지 2/2
    • Disconnect the antenna cables from the WLAN card.
    • Remove one 3mm screw from the WLAN card with a Phillips #00 screwdriver.
    • Pull the WLAN card out of its connection using two fingers on each side.
  14. Dell Precision M4700 Motherboard Replacement: 14 단계, 이미지 1/2 Dell Precision M4700 Motherboard Replacement: 14 단계, 이미지 2/2
    • Use the same steps as used previously to remove the other fan.
    • Remove the two 5mm screws securing the fan to the device with a Phillips #00 screwdriver.
    • Disconnect the cables connecting the fan to the motherboard.
  15. Dell Precision M4700 Motherboard Replacement: 15 단계, 이미지 1/2 Dell Precision M4700 Motherboard Replacement: 15 단계, 이미지 2/2
    • Unscrew the four heatsink captive screws with a Phillips #00 screwdriver.
    • Pull the heatsink out.
    • Captive screws should not be able to be removed. They only screw they do not come out.
    • Be sure to clean both contact points on the GPU and heatsink with isopropyl alcohol and reapply fresh thermal paste before reinstalling the heatsink.
  16. Dell Precision M4700 Motherboard Replacement: 16 단계, 이미지 1/2 Dell Precision M4700 Motherboard Replacement: 16 단계, 이미지 2/2
    • Remove the two 4mm screws connecting the GPU to the device with a Phillips #00 screwdriver.
    • Remove the GPU by pulling it out away from the screen side.
  17. Dell Precision M4700 Motherboard Replacement: 17 단계, 이미지 1/2 Dell Precision M4700 Motherboard Replacement: 17 단계, 이미지 2/2
    • Remove the 5mm screw connecting the daughterboard to the circuit board with a Phillips #00 screwdriver.
    • Disconnect the wide ribbon cable connecting it to the device.
    • Remove the daughterboard by simply lifting it up and out of the device.
  18. Dell Precision M4700 Motherboard Replacement: 18 단계, 이미지 1/2 Dell Precision M4700 Motherboard Replacement: 18 단계, 이미지 2/2
    • Disconnect the wires connecting the CMOS battery to the device.
  19. Dell Precision M4700 Motherboard Replacement: 19 단계, 이미지 1/3 Dell Precision M4700 Motherboard Replacement: 19 단계, 이미지 2/3 Dell Precision M4700 Motherboard Replacement: 19 단계, 이미지 3/3
    • Disconnect the wires connecting the motherboard to the device.
    • The cables should be connected in three locations. Top right, top left and bottom right.
  20. Dell Precision M4700 Motherboard Replacement: 20 단계, 이미지 1/3 Dell Precision M4700 Motherboard Replacement: 20 단계, 이미지 2/3 Dell Precision M4700 Motherboard Replacement: 20 단계, 이미지 3/3
    • Remove four 5mm Phillips #00 screws connecting the motherboard to the frame of the device.
    • Remove two 3mm Phillips #00 screws connecting the motherboard to the frame of the device.
  21. Dell Precision M4700 Motherboard Replacement: 21 단계, 이미지 1/2 Dell Precision M4700 Motherboard Replacement: 21 단계, 이미지 2/2
    • Disconnect the wire connecting the motherboard to the frame of the device.
    • Remove the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mario keller
회원 가입일: 10/30/19
175 평판
안내서 1개 작성함
University of Memphis, Team S4-G5, Kim Fall 2019 University of Memphis, Team S4-G5, Kim Fall 2019 회원
UM-KIM-F19S4G5
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 29
전체 시간: 1,520
