주요 콘텐츠로 건너뛰기
Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
Removing a screen set with epoxy - tool advice needed
I know I screwed up big time, but here it goes.
Two years ago, I had to replace a screen on my S4. The replacement went fine. However, I did not have B7000 glue on hand. Feeling impatient, I used epoxy to set the screen. The repair held up fine; the problem is now I need to replace the battery.
What good prying tool would you recommend to dig through a layer of epoxy between the screen and the body of the watch? Of course, there will be acetone involved.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Vladislav Ekimtcov some isopropyl alcohol in a syringe with a blunt needle to try to soak the epoxy. After that some heat and the smallest dental pick you can find to try to gently scrape away the epoxy. It'll take a ton of patience.....
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Thank you! Did not think the heat would help with epoxy, but seems like it will. How hot does it have to get?
@Vladislav Ekimtcov just try to get the epoxy „Tacky“ don‘t try to melt it since that may cause more damage. You‘d have to experiment a bit, so start with low heat. More of a steady warm…
댓글 달기
답변을 추가하세요
Vladislav Ekimtcov 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 208
