주요 콘텐츠로 건너뛰기
The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
91 질문 전체 보기
Who can fix gamecubes
my GameCube not spinning disc and won't play need to know who can fix them
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
@zora2018 as @guardian10 already pointed out, iFixit does not do repairs. Here you get empowered to repair your own device. Check on this guide and see if you can find anything loose or odd looking. For now, I would consider replacing the drive itself since it does not come on.Nintendo GameCube Optical Drive Assembly Replacement - iFixit Repair Guide It could be a deeper issue so you wan to check the power to the drive. You need a few tools as listed on the guide as well as a multimeter. Even an inexpensive one will work for this. Repair is war on entropy. So let's get it fixed.
You can always post pictures of what you find or what you have trouble with, on your QUESTION. That way we can see what you see and hopefully guide you to a good repair.
Adding images to an existing question - iFixit Repair Guide
Nintendo GameCube Optical Drive Assembly 이미지
안내서
난이도:
운영
30 minutes
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
아주 쉬움
2 - 5 minutes
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
This is not a website for repair services. Ifixit is for manuals and assistance on repairing something yourself.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
If it’s not spinning up and not loading I’d suggest finding and fitting a new laser unit. Loads of vids on YouTube on how to fix things if you want to try yourself.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
keith 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 19
전체 시간: 121
