HR214 SX 1985 No change in the idling speed from HI to LO position.
Hi
I had to change the carburetor because the mower would only work on choke and would die on HI or LO positions. I didn't change anything else. When I pull the lever out of choke down to the Hi position the choke plate opens fully (as per the swivel on the carb) the rpm is pretty much the same but when I put it on the LO position there is no change in engine speed. The motor is GVX120 4.4HP 1 cylinder.
The governor arm is free to move but doesn't not move the idle plate back and forth while idling. There are no restrictions either on the idle arm where the 2 governor rods attach on the carb.
Any Idea?
Thanks
좋은 질문 입니까?
