주요 콘텐츠로 건너뛰기
Repair and disassembly information for Samsung's flagship S21 Ultra Android smartphone, released in January of 2021.
42 질문 전체 보기
no service after screen replacement. can this be fixed?
i had my sreen replaced and now i experience seriously degraded or no signal. i read the answer about that the original antenna needs to be kept. but if it is too late for that is there a fix? i actually paid over 400$ for this problem.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @jaredscott,
Take it back to the repairer and show them the problem.
Most reputable repairers give a guarantee on their work even if it is only for 1 month.
The exception to this may be if the phone had been water damaged.
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
I'm stuck at original antenna has to be kept. Of course it does, that's what provides the signal. So the shop didn't refit the antenna?
Hi @strongbow
At $400+ you'd think that the repairer would know this. If it's lost then they should replace it.
The phone should be tested and in a fully working condition when it leaves the repairers.
@jayeff some shops are more money orientated than about the quality of their work. I for one make sure every part that comes out of a phone goes back in again. Then every function is checked before it goes back to the customer. I can't believe these shops exist.
@strongbow
They can't be relying on repeat business or referrals then ;-)
We have shops the same. Can't believe half the repairs we get that other shops have 'fixed'.
댓글 달기
귀하의 답변을 추가하세요
Jared S Fidler 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 139
