주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
대형 7인치 24비트 True Colour Clear Type 감압식 멀티 터치스크린을 탑재한 Wi-Fi 지원 플래그십 고급 멀티미디어 엔터테인먼트 AV 시스템입니다. 무선 Apple CarPlay, Android Auto, Waze, Bluetooth 및 DAB+ 디지털 라디오(Digital Radio Tick Mark 인증)를 즐길 수 있습니다. 듀얼 USB, HDMI, 듀얼 카메라 입력이 포함되어 있으며 뛰어난 오디오 및 비디오 성능을 제공합니다.
Radio not turning on; AVH-280BT
I was trying to setup some new speakers in my car and while I was testing them the rear speakers weren't playing so I switched some RCA cables while music was playing (cuz I'm clearly a professional....) and heard some popping noise. The radio stopped working. I went ahead and turned the car off, disconnected the battery and checked the fuse (on the back of the radio). The fuse was blown, I switched it and tried turning it on and nothing happened still. I checked the cars fuse box and they were fine. What should I do?
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Check the yellow and red power leads in the deck's wiring harness and make sure they're both receiving power. There might have been another fuse somewhere in the chain that blew. Also check the replacement fuse in the deck - these little fuses are easy to insert incorrectly and they can even fail when they look like they're fine. The deck's fuse has two tiny metal points that you can use to test - make sure there's +12v at both of the fuse's points. If there's power to both leads and the deck's fuse is good, then try "hard" resetting the deck using the procedure in the owner's manual.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
drakeswifer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 22
전체 시간: 432
