주요 콘텐츠로 건너뛰기
삼성 갤럭시 A20은 2019년 4월에 출시되었습니다. 6.4 인치의 스크린 디스플레이와 후면에 듀얼 카메라가 장착되어 있습니다.
20 질문 전체 보기
Dropped A20 now screen is black
Hi, my Samsung A20 was dropped now the screen is black. I've tried resetting it etc. Doesn't work. I'm happy to repair it, I just want to know what to check first so I can get to work on repairing it. Cheers
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 1개
선택된 해법
Hi @rebeccaperth,
More than likely the screen has been damaged internally and it will need to be replaced.
Here's a video that shows how to replace the screen.
Replacement screens are available online. Just search for Galaxy A20 LCD display to find suppliers that suit you best.
If you want to check if the display is the problem or if there's a problem on the systemboard then here's the no display troubleshooting flowchart from the service manual that may help.
(click on image)
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
[code]My phone works but the phone display is black nothing is visible[/code]
Usually if this happens after a drop, it's either a loose screen connector or broken LCD. Open device and check the cable. If that's good and the connection is solid, then I'd say the display layer of the screen is broken. Therefore even though the device is on, you won't see picture. You'll need a new screen.
댓글 달기
답변을 추가하세요
Rebecca Gray 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 1,545
