NO ONES ANSWER FOR THREE DAYS 3ds problem read
It stays on but the screen don’t power on AT ALL and sometime it’ll turn off and make a pop I think its the volume cable but please help
좋은 질문 입니까?
좋은 질문 입니까?
@sqwerks_3464 let me see what we can do with this "don’t power on AT ALL and sometime it’ll turn off and make a pop " Where do you hear the "pop"ing from? Do you hear it from the speaker? Any components on your circuit board looks odd? Have you taken it apart yet? What have you checked? This sounds very much like an issue with any of the flex cables. Take it apart using these guides Nintendo 3DS Then take a really close look at all the flex cables. Because of the popping sound I would suspect the speaker flex being torn, but check all off them. It is possible that this is your top screen flex. Torn ribbon cables can sometimes be really hard to see. I think that is all I got unless we see a bit more of what is going on with your 3DS
Post some good pictures of what your 3DS looks like on the inside. That will allow us to see what you see. 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 81
댓글 6개
what do you mean by 'it stays on'? are there any lights on?
Andrew 의
Yes the blue light the wireless slider does nothing but the charge light works
Sqwerks 의
@sqwerks_3464 sometimes things take a little longer for somebody to look at devices that other are just not used to. Everybody here is a volunteer and spends their free time on here to answer questions.....
oldturkey03 의
@oldturkey03 can you help please? Also if you can tell I made a guide on the 3ds page for the Sd card port so you can have a closer look at it sorry for being rude
Sqwerks 의
@sqwerks_3464 no worries. You are not being rude ;-)
oldturkey03 의
댓글 1개 더보기
