이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Hi,
Was it working OK before?
Have you checked that the signal source is OK by trying another signal input type e.g. if using HDMI input then if the source has Component video + audio output - most DVD players have different output types - then try using that and check?
Hi,
What have you tried?
jayeff 의
