이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Ann Blaser, Does the camera accept a charge? Is the charging done via the same port as the USB is connected? (It’s been a fair while since I worked on a PowerShot.) The more information you can provide, the easier it is for us to help correctly. How to ask a good question on iFixit.
It could be a bad USB port on the camera, which would need replacing. If you take a picture with the camera onto a memory card, then pull the card and put only the card into a computer, are the pictures there?
Geir Ove Andersen 의
