주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
조이콘 컨트롤러와 약간 더 작은 스크린이 통합된 보다 합리적인 가격의 순수 핸드헬드 버전의 Nintendo Switch의 게임 콘솔입니다. 2019년 9월 20일 출시.
Not switching on after fall
My son's Switch Lite fell off his bed and now it won't switch on. There's no apparent physical damage and I can't see any obvious loose connections. It has plenty of battery.
Anyone got any suggestions for what it may be?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
does it make any sounds when the buttons are pressed if it does it could be the screen, other than that there are various reasons that could cause it like cpu being damaged, but its nothing anyone can diagnose online
이 답변이 도움이 되었나요?
점수 3
댓글 9개:
Thanks for replying.
No, no sounds. Fully dead. That is why I thought a loose connection.
Sounds like it could be just about anything, then. I was hoping that there may be a couple of likely candidates for the Switch Lites. I think I'll try a full tear-down and see if anything helps.
@davidartley do you have a multimeter ?
@davidartley in beep mode check the capacitors around the m92 chip to check for shorts, put the red probe on a ground like on top of the charge port and check the caps with the black probe, if any beep on both sides let me know
Excellent, thanks. I will try this at the weekend.
댓글 4개 더보기
댓글 달기
@tech_ni i found four shorts on two separate points.
i have in ingress 0.14A at 5V
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
I don't think they're shorts. I'm sure there should be continuity through those components.
since you only get 5v then its more than likely m92 thats the issue as it controls the 15v. remove it and check again
@nige56 there is only meant to be continuity through the coil not shorted, as the caps above m92 are marked red aswell
댓글 달기
답변을 추가하세요
David Artley 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 36
전체 시간: 292
