Washer leaks from back
I took shell off ran med load.
Washer has drip under basket where it mounts to 4 support braces. What do I need 2 do?
좋은 질문 입니까?
좋은 질문 입니까?
Hi,
you may have to tip the washer over and check if you can see exactly where the leak is coming from. Pour a couple of litres of water into the tub and put some food dye in the water as it may be easier to see where it gets through.
If nothing comes out initially, run a cycle that causes the washer to agitate for a minute or so, just in case movement causes the leak and if still no good drain the water and check.
There is a gasket part #16 (Agitator, basket and tub diagram) under the tub where it may be coming from.
Also check the water drain pump connections as well
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 27
댓글 3개
Hi,
What is the model number of the washer?
jayeff 의
Hi jayeff. Thanks 4 responding. It's an oldie. Kenmore 110.92273100
Richard Salazar 의
@jayeff hi. Kenmore #110.92273100
Richard Salazar 의
