The selected device could not be found error on finder and itunes.
It is a 80gb iPod 5.5 gen with fat32 format. It was working prior to adding 2 songs after my mac glitched I force ejected it and now this is happening please help.
좋은 질문 입니까?
좋은 질문 입니까?
Hi
Have you tried wiping it using disk utility/disk manager?
When I get these sorts of errors that usually fixes it
If not try reseating the battery and hdd connections
Here’s a guide for that
iPod 5th Generation (Video) Battery Replacement
iPod 5th Generation (Video) Hard Drive Replacement
Hopefully this helps
Any questions please ask
안내서
난이도:
운영
20 minutes
안내서
난이도:
운영
30 - 50 minutes
해당 답변은 도움이 되었습니까?
Disk utility was having a rough time loading disks and it couldn't see my iPod, I don't have tools to open the device and the hard drive has a loud high pitched noise and it clicks plus it has 12 pending sectors and 146 reallocs would that be the problem?
Hi
Just from telling from the noise that it makes that is most likely the issue
To add to that 12 pending sectors is quite a lot so replacing the HDD is probably the fix and of that doesn’t work ether a battery or a Logic board
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 277
