주요 콘텐츠로 건너뛰기
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 질문 전체 보기
No signal, but it worked earlier
I recently built my pc and for the past 2 days it was booting up fine I wanted to play valorant so on the 3rd day I went into bios and turned safe booot, valorant worked and it was fine suddenly this morning I opened valorant and my pc crashed I turned it on again and it siad no signal
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
Hi,
More information is need to help you.
make and model number of motherboard,
make and model number of GPU card (if installed)
make and model number of PSU
amount of ram
Is the PC booting in the OS i.e. if Windows (what version) can you hear the welcome sound?
It may not be passing POST.
My pc specs are:
Motherboard - Gigabyte B550 aorus elite ax v2
Gpu- powercolour fighter AMD rx 6700 xt
Ram - Corsair RGB vengeance pro sl (16gb 3200mhz)
Case - Lian li lancool 2 mesh
CPU - AMD Ryzen 5600x
AIO - Lian li gallahad 240
PSU - Gigabyte 650w
Any help would be appreciated.
When I turn on my pc all the lights still turn on and all the fans spin and there is no error code on the motherboard I have tried clearing CMOS but it still says no signal, and I have tried useing a different wire aswell incase the hdmi wire was faulty
댓글 달기
답변 1개
My pc specs are:
PSU - Gigabyte 650w
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Arjan Baweja 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 106
