주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1863, A1905. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
873 질문 전체 보기
How to remove a iPhone 6s sized pentalobe case from an iPhone 8 case?
So I lost my iPhone 8 case screws and I thought a 6s screw would work from one of my broken phones so it went in but now it won't come out. So the threads of the screw have passed the threads inside the phone and now when I screw it there is no resistance so it can't come out.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Insert an opening tool between the screen and chassis above the screw and apply gentle pressure like you were trying to open the phone. With pressure applied unscrew the screw, hopefully it will come out. Done it loads of times with threaded screens.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hey, LogicalBot
I'm not an expert on phones, and I might not fully understand this myself, but I've got a few tips for stuck screws. There are a few things you can try to get it out.
  • Use the exact size screwdriver.
  • Spray lubricant to loosen it
  • Try the rubber band trick.
  • If none of these work, you have a more serious option that I've used for larger screws. I'm not sure if or how it will work on an iPhone.
  • The Glue and Nut method
As I said before, I'm not an iPhone expert, so some of this might not work. I'm sorry if it doesn't, but I hope it's helpful.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I tried to use the exact pentalobe screwdriver but the screw is so far past the thread on the screen my screwdriver can't grip it strong enough to pull it out and back onto the threads.
댓글 달기
귀하의 답변을 추가하세요
LogicalBot 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 37
