이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개:
Assuming the phone was not damaged (e.g. after a fall/liquid spill), here are some guidelines provided by Google to troubleshoot the problem: https://support.google.com/android/answe...
Feel free to let us know if you solved the issue or if you're still having problems after going through the steps
Simone 의
Hi @nathanyacub,
Does the phone indicate that the battery is charging when the charger is connected?
Have you tried using a different known working compatible charger or connecting the phone to a computer's USB port to see if it charges at least?
If it can't charge the battery then the battery will become depleted and the phone won't turn on either way, with the charger or the battery.
jayeff 의
