주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for Panasonic's Viera line of televisions.
Tc-p50st50 flashes 6 error code
I have a 2012 Plasma that will go into a lockout with 6 error code flashes, I can reset it using the power button on the tv, it will sometimes work for a week following the reset before doing the same thing, the next time the reset may only before a matter of seconds. I have checked the boards for signs of failures with not obvious problems. The troubleshooting for 6 flashes states that the most probably fault is the sc board, with the next most probable being the “a” board. I am uncertain how to determine with certainty which board is causing the problem. I did check the boards for loose screw grounding connections, there are signs of arcing in a few locations. Any help on how to proceed is appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi @kwm
Here's an image that shows how to troubleshoot a 6 blink error code to know whether it is the SC board or the A board that is the problem in your model TV.
(click on image)
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks I will give that a try,
댓글 달기
답변을 추가하세요
KevinM 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 13
전체 시간: 406
