Hi,
Did you mean RF4267HARS/XAA?
If so here's the fast track troubleshooting guide for the model.
It has the wiring diagram which shows the connections for the flex zone room (flex drawer?) damper motor and heater
If you find the problem and it is a faulty part, here's a supplier that may help.
Find the faulty part in the supplier's list of parts for the model and then it will show you the manufacturer's part number e.g. part #DAxx-xxxxxx. Search online using the manufacturer's part number only to then find suppliers that suit you best.
Hi,
If you have a DMM (digital multimeter) you can use its Ohmmeter function to check if the components in the flex tray damper control i.e. 2 x motor winding and 1 x heater are electrically OK back to the mainboard.
Disconnect the cable that is connected to connector CN77 on the mainboard and then connect the Ohmmeter as shown in the image below to the harness cable plug - not the mainboard connector
Connecting where the red arrows point will test the "A" motor winding, the green arrows will test the "B" motor winding and the blue arrows the heater.
Even if the motor windings test OK that doesn't mean that the damper is mechanically operating OK or that the problem isn't in the mainboard
(click on image)
