주요 콘텐츠로 건너뛰기
Device repair and information for the Vizio D-series 50" LED television with model number D50n-E1.
77 질문 전체 보기
My tv has multiple lines going across is horizontally
My tv doesn’t even do this when I first turn it on but soon it gradually starts to glitch out horizontally. If I leave it on long enough it stops and then just comes back. It just started doing this and I haven’t touched or moved it at all. Unplugging it gives me 20-30 minutes without the flashing. I forgot my pin so I can’t factory reset it.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
darken this looks like a failure with the LCD driver board (in particular with the Gate Drivers). Those boards are not replaceable and are considered to be part of the panel. There is a slight chance that this could be related to the mainboard (GPU failure). I would try and get an inexpensive (maybe used) main board and see if that will help.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
darken 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 55
