주요 콘텐츠로 건너뛰기
2020년 3월에 출시된 인텔 프로세서가 탑재된 MacBook Air 모델 A2179의 2020년 리프레시 수리 및 분해 정보입니다.
104 질문 전체 보기
Can't charge my MacBook
So i spilled some water on the left side of my laptop, unfortunately when I try to charge it there is no power, but everything else is fine the speaker, lcd,etc works just fine. What should I do please help thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Sistria Nova, First thing to do is to stop trying to charge and use it! Trying to charge and further use it, only increases the speed of which the corrosion starts.
You’ll have to open the Mac up to get access to the boards inside. You can use this guide to get a sense of how to get inside. Note that there are incredibly delicate parts, so you’ll need to be very careful! The first thing to disconnect is the battery. You’ll have to take it completely apart, logic board and all boards out. Once the boards are out, you should use some distilled water to clean off the boards with a soft brush (preferably ESD safe, but a toothbrush will do). Do not use tap water, because of impurities.
Once all the boards are cleaned, use some >99% isopropyl alcohol to go over the boards again. IPA displaces the water and dries off many times faster than the water. Use the brush again, but remember to be very careful! Tiny and delicate components don’t react well to force.
Let the boards dry off for a few minutes, then inspect them using a magnifying glass for any damage or corrosion you’ve missed. If everything checks out reassemble the machine and test it out.
Hopefully it will have been caught in time, if not post some good quality and up close pictures, and we’ll see what we can do :)
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Sistria Nova 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 8
전체 시간: 35
