주요 콘텐츠로 건너뛰기
The Lenovo 14e Chromebook is a Chromebook released by Lenovo on May 21, 2019 as a Educational focused device powered by a AMD A-Series A4-9120 with a base clock speed of 1.6 GHz.
3 질문 전체 보기
How do I attach the hinge base to the lid?
So the hinges on my Chromebook detached from the lid, and it is a pretty common computer problem at my school these days. I have tried to use gorilla glue to secure it to the lid, but it won’t hold. Any ideas?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi @tay0_0
You could try a metal to plastic epoxy resin and see if that holds any better although there are pitfalls when using this according to this adhesives manufacturer who claims to have a better product (idk if it is better or not, never tried it ;-)
Alternative is to replace the LCD cover.
Here's the hardware maintenance manual for the laptop.
Go to p.51 to view the procedure to remove the LCD module. If you follow on from here you'll get to the lcd cover after having removed everything in the lid.
The following are the part numbers for the various covers available for the laptop model series, depending on the Type # of the laptop. The type number can be found on the product info label on the bottom of the laptop.
The part number should also be somewhere on the inside of the cover itself if you wish to verify that you're ordering the correct one.
Search online using the applicable part number only, to find suppliers that suit you best.
5CB0S95313 Type 81MH Touch
5CB0S95225 Type 81MH
5CB1H03274 Type 82M1 and 82M2
5CB0Z69385 Type 82M1 and 82M2
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
tayola 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 170
