Screen acting weird after not even replacing it
I replaced an iPhone 8 back camera and took the screen off to do it. When I put it back and I turned it on it had these columns on it and didn’t look right. I have tried cleaning the connections and reconnecting but just changes a bit sometimes. That should be it but just seeing if there’s any other things it could be or if not best way to clean the connections
좋은 질문입니까?
점수
0
Did you put the display cable bracket back on?
Andrew S 의
@andrewsawesome the first time
Ike Hardman 의
@andrewsawesome and then all the other times I tried cleaning and reconnecting it I didn’t put the bracket on
Ike Hardman 의
You’ve probably damaged a screen ribbon removing it. You could try disconnecting and reseating the connections but I doubt anything will change. Probably need a new screen. How did you disconnect them?
[deleted] 의
Just with a spudger
Ike Hardman 의
