주요 콘텐츠로 건너뛰기
The Dell Inspiron 14 3467 is a 14-inch laptop computer released by Dell.
1 질문 전체 보기
Blinking Power LED 1 Long White 4 Short Ember
I have a Dell Inspiron 14 3000 (Service Tag 91T5S53)
I have been getting a constant Blinking Power LED (1 long white and 4 short ember) I cant seem to find the error code online.
The computer works fine with the power plugged in no issues, but when unplugged turns off immediately, which I thought indicated a battery replacement. I replaced the battery and nothing changed, I still get the same flashing power LED.
The replacement battery is recognized in Windows with a 55% charged capacity but doesn't charge any further nor does it discharge.
I tried uninstalling the Microsoft ACPI-Compliant Control device driver in Device Manager and restarted the computer, but that failed to fix the issue as well.
I have ran the offline Dell Diagnostic several times but comes back with no errors.
I also ran the Dell Support Assist in Windows, and comes back with no errors as well.
There are no BIOS updates as I have applied all available critical and recommended updates.
Can anyone explain what the issue could possibly be and how to fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Hello, how was the problem solved? I have the same problem.
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Create a battery report to check the status of the battery.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value. For a good battery they should nearly be the same.
As far as I could find out a 1 long white, 4 short amber blink error code in Dell laptops means a bad battery.
You may just have got a bad replacement.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
That's usually it with Dell, frankly. The color was amber before Skylake when they went to the white LED, but kept the pattern.
댓글 달기
답변을 추가하세요
Jafric Rhyner (Rasjahshout) 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 25
전체 시간: 920
