주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1989, EMC 3358. 기존 디자인을 새롭게 개선한 모델로, 프로세서 옵션이 업데이트되었으며 키보드 소재가 변경되었습니다. 실버 및 스페이스 그레이 색상으로 제공됩니다. 2019년 5월 출시.
My touchbar is flashing
How do you stop a touchbar from flashing?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 11
댓글 7개
Can you Upload a Video?
의 공유
i think that you may need a replacement, but we need some photos to confirm that you need a replacement or not
의 공유
@djz18 - What Year/Model Number?
의 공유
@beanman56 It's a 2019 13" MacBook Pro 1.4 GHz Quad-Core Intel Core i5 Retina display with 16g memory and 1T hard drive
의 공유
i just updated mine and it stopped.
의 공유
댓글 2개 더보기
댓글 달기
답변 2개
선택된 해법
Just spoke with Apple support again and she mentioned a step no other support advisor mentioned...reset the NV RAM. To do this, I held the Option, Command, P and R keys while starting the computer. I held the keys for 20 seconds and the computer did another restart, after which I released the keys. This has stopped the flashing for now. If the flashing restarts again, I'll add to this post. Thanks for your input, if you had responded to this post.
이 답변이 도움이 되었나요?
점수 8
댓글 3개:
After using the computer for a couple of hours, the problem with the touch bar is back.
의 공유
Now what? It also worked for a very short time
의 공유
Apple might not endorse this but a strip of gaff tape over the whole thing solves the annoying flashing. Blacked out and gone. Battery life will probably still exceed woeful but, hey! it is a Mac!
의 공유
댓글 달기
In my experience this is a sign that the Touch Bar's display is failing and needs to be replaced. It's not an unusual issue, but it is a bit of a gnarly repair due to the sheer amount of adhesive involved.
This is the process for a 2020 model, which will be quite similar as far as getting the touchbar itself out. Just for point of reference.
이 답변이 도움이 되었나요?
점수 6
댓글 2개:
Thanks Alisha. This is very helpful. I don’t think I want to take this type of extensive repair on myself. Do you know a good place to send it for this type of repair, other than apple?
의 공유
@djz18 That's a good question. And I don't blame you for not wanting to undertake it yourself. I would ask friends or family if they have any local recommendations. I don't have any specific suggestions, aside from not Apple since they will not do this repair independent of a full top case replacement, which is quite pricey.
의 공유
댓글 달기
답변을 추가하세요
David zeve 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 10
지난 7일: 46
지난 30일: 160
전체 시간: 22,638
