주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
590 질문 전체 보기
Where are the power pads located on the logic board?
Does anybody know where the power pad is on a 15" 2010 Macbook Pro's logic board?
I suspect there is a problem with my Macbook Pro's top case power button due to it not powering on, however I would like to double check and see if the logic board is functioning or not so I'd like to jump start it.
(A picture would be a godsend right now.)
Thank you for reading.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Dusty, this might be what you are looking for (see attached image) :-)
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
Got it! Thank you so much!
i need a bigger image please
Here's a bigger image as requested by Carlos Madrigal.
The power-on pads located right above the keyboard/trackpad shield.
[image|257723|align=left]
[image|257724|align=left]
You can find the power-on pads location for other MacBook Pro models here:
MacBook Pro power-on pads.
댓글 달기
macbook pro a1260 not on. what problem can you halp
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dusty 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 6,845
