주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1993년 후반기에 출시한 Macintosh Quadra 610과 Macintosh Centris 610은 각각 밀접한 관련이 있는 Apple Computer의 Quadra 및 Centris 시리즈 개인용 Macintosh 컴퓨터입니다.
Why won't the computer start?
no image start up on monitor
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Any sounds? Does the motherboard runs? Do you hear power supply unit working?
There may be many reasons:
- power supply is dead (if nothing happens after power-on)
- battery is dead
- chipset is dead
- memory is dead
- tarnished contacts (power is not supplied to motherboard at all, or not enough power for components)
opix.pl
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
replace battery, and it does not work--- hear not working tune;
hit option command R and P along with start button, and does not work--- hear not working tune,
의 공유
also, green light comes on, but no screen picture, just the not working tune.
의 공유
In addition, the computer worked the last time I used it 15 years ago, that's why I thought replacing dead lithium ion batter would revive it, but no, just the I'm not working tune plays. In additon, I can hear the hard drive, and fans working.
의 공유
it is more possible that the video wire may be broken, or the VGA adapter is corrupted (try by AV cables if you connected it earlier via adapter). If not I would open the chassis and look for solder cracks. Ah sorry I didn't noticed you mentioned not working tune - focus on the hardware, skip video wires, I was wrong.
의 공유
댓글 달기
The first thing I would do is install an new 3.6 volt 1/2 aa Lithium PRAM battery.
You can get it here: https://www.amazon.com/Brand-LS14250-Lit...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
good choice for 1st step - usually computers do not die if not used, but internal batteries runs out :)
의 공유
댓글 달기
답변을 추가하세요
Denton Fender 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 33
전체 시간: 584
