주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
납땜은 두 금속 조각 사이에 다른 필러 금속을 녹여 두 금속을 연결하는 방법입니다. 납땜에는 여러 가지 종류가 있지만 이 글에서는 전기 납땜의 기본을 알려드리고자 합니다.
I'm looking to repair the wobbly micro-usb port on my Fii0 E10k DAC
I'd like a longer title but it doesn't appear to be allowed.
So i'm looking to repair my USB DAC because it does not receive power unless the USB port is pushed in a certain direction. So I'm thinking that the solder points have broken.
I have taken it apart, however looking at the back and wobbling the connection I don't see any movement, so I *think* that the solder between the port and the connection point is whats broken, but due to other things on the PCB I can't get a good look (and it doesn't wobble much, theres 2 connections holding it in place so the other must still be good, probably wobbles maybe 0.5mm either way, but apparently thats enough to cause a disconnect from the pins). It could also be a pad, i'm not 100% sure.
So keeping in mind that I'm a complete begginer, and my limited supplies (I haven't ever soldered anything before, I only have a soldering station and some solder, no flux or any other equipment) what should I try? Should I just stick a soldering iron on the presumably broken joint and get it to hopefully re-solidify in the right way for it to fix my USB port and maintain contact with the pins? I have a small budget for this, $50 AUD if I need to get more supplies, any more then that and i'd rather just get a new DAC as it was just a bit over 100 AUD.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
@sol33t303 if you have never done this before, I suggest you get a couple of old practice boards first. It is not a terribly complicated repair but does require some practice. You do not want to damage the board or rip the traces because of a too cold or even a too hot iron. Even so YouTube can't teach you to solder, but there is at least enough information that may help you to get started on a successful repair. Even guides like this How To Solder and Desolder Connections - iFixit Repair Guide can be helpful. Practice, practice, practice will have the largest impact on a good repair.
Post some pictures of the loose connector etc. with your QUESTION. That way we can see what you see and maybe give you some pointers. Adding images to an existing question - iFixit Repair Guide
Soldering 이미지
안내서
연결부 납땜 및 납제거 방법
난이도:
어려움
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
매우 쉬움
2 - 5 minutes
이 답변이 도움이 되었나요?
점수 2
댓글 달기
you could maybe get it repaired for that price by someone with experience and the other tools, but if you want to try it yourself at least get flux, kingbo will do fine but do not use plumbers flux as its corrosive
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I'd like to try it myself, I have had many devices face similar fates (tends to happen when I drop something while plugged in, phones, controllers, headphones, etc. Or when I otherwise knock it and damage the port) so i'd like to learn how to replace/fix the ports that I break.
If I can't do it with what I have I'll order some flux, a bag of ports and a de-soldering braid as well. I live rurally though and delivery takes a long time.
의
댓글 달기
답변을 추가하세요
William Parry 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 26
전체 시간: 687
