주요 콘텐츠로 건너뛰기
The 2018 version of the Samsung Galaxy A7 smartphone released in October 2018.
49 질문 전체 보기
Soket of charge not work good
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Use a strong light and a magnifying glass and check that the USB charge port enclosure is free from any lint etc that may be preventing a good electrical connection.
Also ensure that the pins are all there and that they're straight a parallel with each other and not bent etc.
If there is any debris in the port enclosure, do not use a metal pin or probe to remove it as you may damage the pins. Try removing it by using a vacuum cleaner instead.
If the port seems OK then perhaps it is a loose USB connection on the charge board in the phone. The phone would have to be opened and the port further checked.
Here's a video that shows how to replace the charge port (supplier examples only) that may help.
If doing this yourself seems too daunting, contact a reputable, professional mobile phone repair service and ask for a quote.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Ehab Fathy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 18
