주요 콘텐츠로 건너뛰기
Model A1989, EMC 3358. A refresh of the existing design, with updated processor options and a change to the keyboard materials. Available in Silver and Space Gray. Released in May 2019.
123 질문 전체 보기
Touch bar non functional after tear down
I tore down my Macbook Pro to look for water damage, when putting it back together and powering on the touch bar no longer works or turns on. Any advice?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
This is going to sound silly, but have you logged into your Mac to verify this? If your Mac has FileVault enabled, the Touch Bar will not come on until you have unlocked the disk (by logging in).
It may also be that it was damaged by the spill depending on where water went. Liquid damage to the Touch Bar can be difficult to detect without some serious surgery.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
I did log in and I also didn’t find any water damage
@schrammalama0 Not finding any liquid on the interior, doesn’t necessarily mean it didn’t damage the touchbar.
That aside. If you’re not getting any image on the touchbar, I would make sure the cable for Touch Bar display is seated properly. It’s the one along the curve of the fan (on the right side if you’re looking at the laptop with the bottom removed) that wraps around the board.
It can be a bit fussy to get it connected properly. And because of some tight clearances, it’s not unusual to accidentally tear the cable trying to plug it back in again.
댓글 달기
귀하의 답변을 추가하세요
Porter Schramm 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 35
