주요 콘텐츠로 건너뛰기
Repair guides and support for computer monitors produced by Samsung.
makes a high pitched noise
Hi, I am still having this issue with my Samsung odyssey crg5 that makes a high pitched noise I have messed around with all the settings and still makes the same noise. Is there any other suggestions?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
I have a Samsung Ultrawide 34" sold by Costco. The way I fixed it is to make my brightness 100% and then decrease my contrast. I'm normally a high contrast low brightness person, but the high pitched noise was driving me nuts. So This is my compromise and I hope it worked for you.
You probably recently downloaded an app that is altering the microphone functions. Uninstall the app
댓글 달기
답변 3개
가장 유용한 답변
@scholten sounds to me like your monitor is experiencing a form of coil whine. Usually you can decrease this by changing the GPU settings on your monitor. i.e. brightness, color temp, etc. Also, try different inputs and see if that makes a difference. If not, open it up and see if you can determine which coil (or other component) makes that whining noise. There is a possibility of decreasing it by using some thermal pads etc.
Once you know where the whine comes from, post some good images of that area with your question
기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Oh I see so is coil whine does not damage anything over time? I also have messed around with the monitor settings and changed the source. The sound was definitely quieter as I increased the brightness but I can still hear it. And changing the source still made no difference.
@scholten no it does not. It‘s annoying as heck but its part of the component. Of course, quality of that component is a big factor. There are ways to minimize the whining noise but not really to get rid of it. You just stop hearing it ;-)
Ah okay, I usually have headphones on when playing anyway. It just really notice it when the room is quite and I don’t have my headphones on
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
You probably recently downloaded an app that is altering the microphone functions. Uninstall the app.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Shaun 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 106
전체 시간: 5,548
