주요 콘텐츠로 건너뛰기
Repair guides and support for your Samsung TV.
2614 질문 전체 보기
The TV will not turn on.
I’m having the same problem. Here is a picture of the power board.
It looks like the fuse is a fixed fuse and can’t be changed. Is this the case?
It is an older TV and hasn’t been used in a while.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Llora Jones that is a soldered fuse. Don't just change it for the sake of changing it. Check it with a meter for continuity. If it tests good it is not the fuse. IF you do have to change it change it with teh exact model. The type of fuse and the ratings are silk screened on the board just above the fuse
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi Lora,
Well, yes and no. It can indeed be changed, but it requires soldering to do so.
Of course they had to put that paper inside the glass tube so you can't just visually examine the fuse to see if it's blown either; you'd need an ohmmeter or continuity tester to be able to tell if it's still good or not.
$0.10 worth of extra parts and they could have added a fuse holder making soldering unnecessary, sigh.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Llora Jones 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 11
